peakyquest
(Haroon Rasheed)
June 11, 2024, 6:47am
1
I want to send the data from companion computer to flight controller, how can I do that ?
I read this article, which was helpful, but I dont want to use MAVLINK, is there any other way where I can send and receive data only from UART?
https://ardupilot.org/dev/docs/raspberry-pi-via-mavlink.html
peakyquest
(Haroon Rasheed)
June 11, 2024, 6:58am
2
if I want to use my custom protocol, where should I write the code of it in ardupilot repository?
You would need to use lua scripting, no need to change the C++ source code for that:
https://ardupilot.org/copter/docs/common-lua-scripts.html
But usually MAVLink is a better way.
peakyquest
(Haroon Rasheed)
June 11, 2024, 8:11am
4
ok thanks, I will look into this article.
peakyquest
(Haroon Rasheed)
June 11, 2024, 8:51am
5
Can I test these lua scripts on SITL ??
Yes. You can do it the same way as on a real vehicle.
peakyquest
(Haroon Rasheed)
June 12, 2024, 5:54am
7
Thankyou so much, I have understood eveything
