How well I know. We live just a hop, skip and jump from Canada. We have friends in Ontario and if we send them something on UPS we send it to Ryden’s Border Store on the US side of the border, and they drive down to get it. Otherwise the chances of them actually getting it are about 50-50, even with the VAT and declaration already taken care of for Customs.
I’l post some details of my x3 build. It may be awhile as I’m still in the designing stage.
So I had a presentation that I developed to document my development of the X3. I modified it to bring it up to date. Compound Helicopter Design
I briefly describe my plans for the new design. I will provide more detail on my plans for the new design in another post.
Regards,
Bill
So, I was looking up reversible ESCs. Most modern min-quad blheli compatible ESC’s should be able to do the job.
However, it also made me think of how to control the amount of thrust in forward flight?. Do you tie it into the collective or cyclic?. You could put it on a separate channel, but then you’ll need to map it to an easy-to-access control, like a slider.
Jakob,
I used a slider to control the thrust of the propellers in stabilize and althold modes. I was not sure how to implement the boost control in controlling the aircraft in velocity command modes and auto modes. I started a discussion on the developer team section to get feedback and ideas.
The trick with DDFP is to select the right props. Normal quadrotor props only have a one-way airfoil. They produce some thrust in reverse, but only about 40-50% of what they produce running the right direction.
There are some props for quads with reversible motors that may work fairly well, but I don’t think those have a very efficient airfoil.
I theory, I think it could be done with DDFP without reversing props too. it would use just one thruster for yaw control in hover like a DDFP tail does. And the heli would hover with a nose-up attitude. But the size of the heli would probably be limited to 500 class or smaller. I have never been able to get DDFP to work all that will with a 600-class heli. It has no problem as far as available thrust. It has a problem with how fast the tail rotor can be throttled and respond for accurate yaw control. A friend of mine flew a Trex 550 with a DDFP on it for awhile and it worked reasonably well. But not as good as a conventional tail. He eventually went to DDVP with a y-cable on the main rotor ESC/tail ESC. And is now flying our dev code where we have DDVP working again.
In the end, I think DDVP will give better results. But I would not hesitate to try DDFP on a 500 class compound.
That motor is a Tiger 3508-630. The shaft diameter has to be machined to fit the bearings in the motor because the shaft diameter for the slider/pitch assy is larger than the bearing ID in the motor. You need to machine a small flat in the shaft for the grub screws on the rotor bell, and a small circlip groove on the base of the shaft for the circlip that retains the shaft in the rear motor bearing.
The air hardening drill rod is pretty hard but can be machined a couple mm with emery cloth in a high-speed lathe, or use a crankshaft grinder. For folks that don’t have the machining tools, a machine shop can do it in few minutes and shouldn’t cost too much if you take the stock shaft along so they have the dimensions that it needs to be machined to.
Is it easy to get custom parts made if you don’t have the access or training for machine tools. I can provide either paper or cad drawings. Sorry if it’s off topic but I’m interested in the project. What is DD. I got the fixed vs variable pitch part. I was to build a central motor VP quad just for fun. I’d like torque tube drive but need a few custom parts.
@bnsgeyer I’m curious about your Level Flight Performance Graph. Are the points on the graph the actual test points, and the rest of the graph extrapolated?
I’m comparing to test data from my Synergy 626, which is about the same size heli (maybe a bit bigger because of 1,390mm main rotor). But the takeoff weight is about the same, 14.8lbs (6.7kg) for the 626 carrying 6600 12S. My hover power is 850 watts (1.14hp), or ~127 w/kg of aircraft weight @ 1,630 rpm.
Cruise power at 15 m/s is 670 watts (~100 w/kg), 20 m/s is 905 watts (~135 w/kg), 27 m/s is 1,320 watts (~197 w/kg).
My numbers were gotten from the Castle ESC’s internal logging, which may or may not be 100% accurate. But I think it’s at least as accurate as the Pixhawk PM’s, if not more accurate.
I made several modifications to the heli to get those numbers
vertical stabilizer adjusted to provide all the yaw authority for forward flight
reduce tail drive ratio from 1:4.5 (7,330 rpm) to 1:4 (6,520 rpm)
replace stock 96mm tail rotor blades (321 fps blade tip speed) with 106’s (308 fps blade tip speed). The bigger tail rotor blades are more power efficient, better yaw authority, and less driveline losses running at lower rpm.
So while the performance curve is pretty flat from translational lift to 20 m/s, it starts going backwards at cruise speeds much higher than that. It will be quite interesting to see if the compound design is only suitable for getting higher cruise speeds without RBS problems, or if it is actually more efficient than a conventional heli. I could not find any fuel consumption vs cruise speed numbers for the EuroCopter x3 concept aircraft to compare with conventional.
Edit:
Had to double check my math because I took the numbers off my spreadsheet that never actually figured out watts/kg or fuel mileage. Had to make a correction for a typo on the 27 m/s cruise, and the rotor diameter. It was 1355mm stock, with the 626 blades it is 1,390mm.
Yes. The points on the graph are actual test points. And the power data was taken from the internal logging of the Castle ESC.
I hadn’t played much beyond the initial redesign to 4 bladed rotor to look at high efficiency. I was worried about yaw control with the smaller tail rotor blades. So I didn’t want to bring the rotor speed down too much. Also I may have been premature in my concern of settling with power. I like the way you judge your minimum rotor speed based on hover collective pitch setting. In full scale helicopters we use a metric Ct/sigma which I show in the slide show. They know for full scale helicopters where this should be to keep away from blade stall but I’m not sure how well that translates to model scale. So I’m assuming that you don’t have to be cautious with your approach to hover, worrying about the aircraft settling as you pull into hover. I distinctly remember that happening quite a bit with my two bladed version.
So to compare our power required, we would have to be at the same Coefficient of Thrust (Ct). Mine is slightly higher (0.0028) to yours (0.0025). It essentially generalizes your weight with blade length, rotor speed and air density so you can compare performance. I’m not saying that mine is more efficient or not but to compare apples to apples, we should be looking at aircraft at the same Ct.
Right, and that can depend on airfoil type used too. If you remember, I tested four different types of blades I bought at IRCHA, specifically to test for power efficiency. I am, of course, flying the ones that had the best numbers (Rails).
Those numbers are with the 1390mm main rotor diameter and 275mm tail rotor diameter.
Quotes out of order here, but no. I have zero settling with power problems with the 626. It is the one that I was able to recover with, testing the inverted flight code in 3.6-dev. When the heli flipped over, there is no collective lead-in built into the code so it falls like a rock when it rolls 90 degrees. Despite the fact that it is a very poorly implemented roll with a helicopter, the 626 handled it fine at full UAV weight.
This works very well because any airfoil has a most efficient angle of attack range. You want to be hovering at the upper end of that range, and cruising at the lower end.
Certain the blades will change the performance. I’m just saying that the way to compare aircraft performance goodness would be at the same Ct. There are many other things that can be baked into the design that would make one aircraft excel in performance compared to another, airfoil selection being one of them.
Ah, OK. I wrote that one down to remember in my Important Notes (actually copied and pasted into my Important Notes in my computer, but same thing)
I think you may have been running too low of a headspeed for the weight and type of airfoils used. My opinion with UAV heli’s is that people get carried away with low headspeed, just to get a few extra seconds of flight time. I like to shoot for a compromise between flight time and performance. So I have my governor set up to run 390 fps blade tip speed for lower speed flight (hover collective around 7.2 degrees). 420 fps for high-speed flight (hover collective around 5.5 degrees). I’ve found that the higher headspeed is a plus for handling qualities and stability in high speed flight, or windy, turbulent conditions.
Our RC heli’s have quite low disc loading compared to even light utility helicopters. Light utility class is usually 2.5 lbs/ft^2, or more and typical blade tip speed of 550 fps. Heavy lift heli’s will run up to 14 lbs/ft^2 and 700 fps. The largest and most powerful heavy-lift helicopter on earth, the MIL Mi-26 Halo, has a takeoff weight of 123,450 lbs with a main rotor area of 8,657 ft^2, giving 14.2 lbs/ft^2 disc loading @ 132 rpm, or 725 fps blade tip speed.
I think the compound designs shooting for higher flight speeds are going to have to keep the headspeed up for decent handling qualities. At 420 fps the blade tips are traveling 286 mph, giving relative speed of 186 mph @ 100 mph flight speed, which even in wind should not reach the critical AoA for the airfoil and have RBS problems. But whether or not the handling qualities, and tuning of the heli, will be adequate at those flight speeds for it to remain stable is still to be tested. I have watched the Speed Cup competitions (and participated in a couple of them), and 130 mph with a stock 600-class machine is easily attainable with excellent stability. But the headspeeds used run the blade tips at ~550 fps (light utility heli class). Part of that is to get the power and acceleration for the run. But a big part of it is stability too.
