Compass Extra Sensitive to External Interference
Hi the compass performance is pretty good flying, can’t fault it in the air except for what you can see in the plots below. Compass is custom RM3100
When below 6m of flying height compass sees small variations and regular yaw resets and up to 45 degrees if placed on a desk which is much more sensitive from what I have seen before.
It is a good distance from other components except the gps aerial. The GPS SMA fitting is brass with nickel coating and lead free solder used.
On the ground I occasionally see error messages like this: Check mag field: 48, max 875, min 135
Do I need to make a larger (10mm) gap between the aerial sma fitting and the compass sensors? A lot of work to test the thesis… :slight_smile:
Here is an inflight log with some anomalies.
Have you tried to run a magfit calibration?
I haven’t tested it. It large spikes look like something other than calibration issue would you say?
If you have good current sensing then Magfit will give a current offset that might clean that up. It’s an easy test to see if there’s an improvement before you go and re-wire the drone to move the compass.
I’ve done motor calibration using the bench test. I will do a magfit calibration before my next flight.
Are those spikes normal?
Motor interference is not significant.
https://firmware.ardupilot.org/Tools/WebTools/MAGFit/
https://ardupilot.org/copter/docs/common-magfit.html
Magfit is done with a flight log.
No, the spikes aren’t normal but this “might” be an easy fix. Especially if you say making a larger gap between components is a lot of work.
Could these spikes be caused by a connection issue. I do see compass unhealthy randomly also.
