We are trying to establish a variable (perc_piezo) in the AP_MotorsMatrix code while calling code from the RC_Channel code but we can’t figure out how to write call the RC_Channel while in MotorsMatirx. (output_piezo) is the function we tried to create to use it. Let us know if you have any questions.
- tried adding #include
- tried using float vs void
AP_MotorsMatrix.cpp (try #1)/ also same code written in RC_Channel.cpp
float RC_Channel::output_piezo(RC_Channel::aux_switch_pos_t &ret) const
// calculate position of flight mode switch
const uint16_t inp = get_radio_in();
if (inp > AUX_PWM_TRIGGER_LOW) {
perc_piezo= 0.0f;
return 0.0f;
} else if (inp < AUX_PWM_TRIGGER_HIGH) {
perc_piezo= 1.0;
return 1.0;
} else {
perc_piezo= 0.5;
return 0.5;
AP_MotorMatrix.cpp (try #2)
const uint16_t inp = RC_Channel::get_radio_in();
float RC_Channel::testfun() const{
//perc_piezo=1.0f;
return 1.0f;
float perc_piezo=0.0f;
RC_Channel.h
// pwm value above which the option will be invoked:
static const uint16_t AUX_PWM_TRIGGER_HIGH = 1800;
// pwm value below which the option will be disabled:
static const uint16_t AUX_PWM_TRIGGER_LOW = 1200;
float output_piezo(aux_switch_pos_t &perc_piezo) const;
Expected it to compile so we could change the values for perc_piezo between 0, 0.5, and 1. It didn’t compile because:
error: cannot call member function ‘int16_t RC_Channel::get_radio_in() const’ without object
