I have been using arducopter terrain-following feature by downloading the terrain data from https://terrain.ardupilot.org/
But it is getting repeated every time if I have to go to a new area. The maximum radius we can generate using the above link is 400km. So will have to download manually all the files. Or I can also download data on a continental level. But this increases the requirement for onboard storage. Is there a way that I can define the boundary at the country level, clip the data and download it in DAT format so that I can store it on the autopilot’s SD card?
I don’t know the file format but…
I tried to document.getElementById("radius").max = 3000
to increase the radius but seems like the server has a limit in this line:
You can clone the repository and run it by removing that line with the radius that suits your application
Thank you for the reply.
Do you have any idea why is there a limit on this?
I wouldn’t be supporised if it was done for performance reasons.
