Had a good flight today with Chibios master build on a custom flight controller, Standard PID settings are way too high for a small quad. Had to drive them down beyond the lower limit. I’m using TBS crossfire micro RX set to Mavlink Rx and TX connected to Serial.
Found an issue when doing the radio calibration where if the Speed of the TBS Micro RX is not set to 50hz the bars jump about in MP when moving them, tested on another mico rx and its the same. Dont know why this is and it doesn’t make much sense to me.
I’m using 2.25Beta firmware in TBS Crossfire
Note : Issue has been solved, Problem is with the inverter XOR on usart not the crossfire micro
