hello dear friends
is there any way to change fligh mode in a specific waypoing by itself…for example i wanna add a waypoing on the last waypoint and when the plane reached that waypoint flight mode change by itself for example from auto to fbwa…
thanks for helping
Hey !
Except from scripts (lua, python) I don’t know any way to do this,
However it depends the mode you want, for instance you have RTL, land and loiter available maybe you can do a loiter and then when you are ready take back your vehicle manually to witch to the desired mode.
What is your motivation to do so?
Might be an alternative.
BTW, you can use DO_AUX_FUNCTION for that.
Parameter 1 should be any number of AUX_FUNC enum in here:
For example, 92 for changing mode to FBWA.
Param 2 should be 2.
Here is an example mission list:
QGC WPL 110
0 0 0 16 0.000000 0.000000 0.000000 0.000000 -35.363262 149.165237 584.070007 1
1 0 3 16 0.000000 0.000000 0.000000 0.000000 -35.361454 149.162930 30.000000 1
2 0 0 218 92.000000 2.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1
