I want to make the copter point at an object in guided mode.
I now have control of the copter via UDP and can make it move in X,Y and Z using the SET_POSITION_TARGET_LOCAL_NED.
However, I can not make it rotate i.e. change yaw.
There is a part of the SET_POSITION_TARGET_LOCAL_NED command reserved for yaw but apparently it’s not implemented in Copter.
Do you have an idea on how to change yaw on guided mode?
