Cessna aircraft SITL using sim_vehicle.py
Hello people!
May I ask if you know how to simulate a Cessna aircraft?
By using command --help, ArduPlane: CRRCSim|calibration|firefly|gazebo-
zephyr|jsbsim|last_letter|plane|plane-3d|plane-
dspoilers|plane-elevon|plane-ice|plane-jet|plane-
soaring|plane-tailsitter|plane-
vtail|quadplane|quadplane-cl84|quadplane-
copter_tailsitter|quadplane-ice|quadplane-
tilthvec|quadplane-tilttri|quadplane-
tilttrivec|quadplane-tri|scrimmage-plane
There is no my ideal Plane. how can i apply my own aircraft just for sitl? Can anyone help me? By the way , while following Using SITL with X-Plane 10/11 — Dev documentation (ardupilot.org) , building and running SITL using sim_vehicle.py and MAVProxy, In the end, it was not possible to compile successfully like the default aircraft mentioned above, and mavproxy could not run successfully. The ground station Mission Planner also failed to connect.
