Cc3d revolution mini in 2024
https://ardupilot.org/copter/docs/common-openpilot-revo-mini.html
I am planning to buy this flight controller at the end of 2024. I just wanted to ask how many years it will continue to receive ArduPilot updates. In short, is it still worth buying this flight controller in 2024?
any help would be much appreciated
It is already outdated today:
STM32F405RGT6 ARM Cortex-M4 microcontroller
168 MHz/1 MB Flash
Buy something with an H7 processor instead of a F4 processor. And 2MB Flash minimum
@amilcarlucas ok thank you for replaying Can you suggest any good H7 processors?
Use a ST32H743 :grinning:
Look here:
https://ardupilot.org/plane/docs/common-autopilots.html
for example
Mateksys H743 slim or mini
Matek has a new board at a bit lower cost. H7A3-Slim. Only downside is no Sd Card reader so no scripting.
HolyBro Kakute H743-Wing is this a good flight controller
Yes. Very popular.
NxtPX4v2 I have finally decied to go with this one It has 2mb flash and a H7 processor is this a good choice?
Is it supported by ArduPilot?
yup you can read the documentation here NxtPX4v2 - Flight Controller - MicoAir Tech NxtPX4v2 — Copter documentation
It has not seen common use on the forum here. No Sd card? Can’t run scripts if not. Perhaps if you ask in a thread that isn’t title Cc3d you might get a better answer.
