Hi, I’m running APM Planner on Mac Catalina,
Strange, if I connect my Pixhawk 2.4.8 it works and I get a connection.
If I try to load a new FW onto the device, I got only a blank screen
Any ideas? (btw I’m a newbie - but I have experience with other FlightControllers (FPV), …)
Ok
Could you run it from terminal to see what error happening ?
In the apmplanner application there is a macos folder that contains a binary drag and drop it to terminal then go to firmware screen and send a screenshot of terminal
OK
in the last line you can see that APMplanner couldn’t detect your board, it could be a bug or old boot loader version
try to run mission planner on mac with vmware or wine then flash your Pixhawk
or simply use QGC on mac
hi, thanks for your help - it will work on my mac with your suggestions.
But - before I read your message, I put my board into DFU-Mode and uploaded manually the firmware - it worked too - but it was a mess to find how I put this fu…ing china board into dfu - see my picture
