I have a black CUBE PixHawk2. It contains 3.5.5 firmware and I tried to update it. I can connect using MP and read and write parameters, so I know I have the correct COM port, but when I try to upload FW, it gets hung at the “determining board type”. When I go into TERMINAL and try to connect, is reports “cannot open COM port”. I even tried APM Planner in order to load the latest code, but that doesn’t work either. Ideas?
When I use update firmware manifest, it gets to the “scanning com ports and hangs”.
