Hello there. Prior to my indoor flights, I re-calibrate the compass then went back to the lab to check the logs. The logs are there, I can download the logs but the time stamp is on January 1st 1980, 8am for all 4 flights. When reviewing the logs, it doesn’t graph the data as it should. Instead, it shows a vertical line on all data. I’ve attached a screenshot of the review graph and the log file. I hope someone can shed a light on these. Thank you.
Log file: https://drive.google.com/open?id=10dZwtbIGhvnSEFbhqO3zGKGM98gxwGQa
