I’m having some trouble with my first arducopter build. I’m using a 4 in 1 BLheli_32 esc, and I’ve got it connected to pwm pads 1-4 on my Matek F405-CTR. I can’t for the life of me get them to initialise (make the two beeps after the 3 power-up beeps). I verified before flashing ardupilot that they all worked with DShot1200 and 600 in betaflight.
I’ve set MOT_PWM_TYPE to 7 (also tried 6) and I’ve made sure the motors are mapped in the servos page. I’ve tried 3.6.6, 3.6.7 RC and 3.7.0 dev. I’ve made the minimum PWM value 1000.
Ah ok, I’m using crossfire, works great! I suspect your RC in issue likely needs its own thread. As far as I could dig up though, from the wiki page and hwdef file, UART2 is not enabled for this board, and that’s the one with the inverter for frsky SBUS. Not sure if that’s of any help! Perhaps try tapping uninverted SBUS (if you can on that rx) and sending it to a different UART.
Good find! Hate to tear the thing apart again. Think I’ll go mess with iNav a bit more and then revisit Ardupilot when I eventually crash and have to do some repairs
