I’m new with flight controllers and Ardupilot but making great progress so far with the help of the wonderful community and documentation.
I’m trying to get the OSD working, but after fiddling with it for hours, I’m throwing in the towel and asking for help. The video works fine, but I can’t get the OSD to appear.
I’m using a SpeedyBee F405 Wing Flight Controller with Ardupilot 4.5.7.
I have a Walksnail Avatar HD Mini 1S Kit VTX and camera combo (38.43.13) connected to Serial 5 - SpeedyBee docs call this the “Digital VTX” port but I’ve also tried on the “Analog VTX” port with no success.
The goggles are a Walksnail Goggles L.
The VTX powers up just fine and transmits to the goggles. I have the TX connected to the RX and the RX connected to the TX between the VTX and the SpeedyBee flight controller. The 2nd GND (2nd black wire) and SBUS (yellow wire) are disconnected.
I’m using the following configuration:
OSD_CHAN 0
OSD_OPTIONS 1
OSD_TYPE 3
SERIAL5_BAUD 57 (but also tried 115)
SERIAL5_OPTIONS 4
SERIAL5_PROTOCOL 42
I have 3 OSD screens enabled in Mission Planner. I don’t know what else to do to get the OSD working and I would appreciate any help.
Let’s just rule out a few things. If this works then we can sort out the multiple screens.
OSD_ARM_SCR,0
OSD_DSARM_SCR,0
SERIAL5_OPTIONS,0 # this file still showing 4.
SERIAL4_PROTOCOL,-1
SERIAL2_PROTOCOL,-1
SERIAL6_PROTOCOL,-1 # some times having multiple ports set to the same thing like this will cause issues.
Don’t forget to power cycle the flight controller after making changes to the serial settings.
And have you got the fonts turned on in the googles? And of course double check the wires. Usually walksnail is pretty straight forward so it’s going to be something simple.
@Allister , you’re a wonderful human! Thank you so much for the help! It’s working now.
For anyone else that may have this problem in the future, only assign DisplayPort to ONE serial port and also reboot your goggles between changes. I incorrected assumed the OSD would appear on the screen, but it actually didn’t appear until after the goggles rebooted!
I just set up OSD from Ardupilot to Walksnail. Thanks for the tip about rebooting goggles.
I had to update Mission Planner to get the HD checkbox in the OSD settings.
I also had to revisit some of the settings a couple times. In particular, I’m confident I set SERIAL5_PROTOCOL 42 early in the process, but when I was triple checking everything later found it was MSP not DisplayPort. I’m not sure if a parameter write failed, the MP update changed something, I forgot to save / mis-clicked, or what.
Otherwise, just followed the docs. This was using a Matek F405 Wing, with the 12v solder pad bridged so the Vtx gets 12V instead of 9V, Goggles X, and Avatar GT kit, firmware 38.43.13.
