I wan’t to do a simple task with my copter , just takeoff to 5m and start to rotate with the speed of 10deg/s. I use WiFi data transmission to connect my drone from my laptop , and run dronekit scripts on it.I’ve test it in SITL before real flight , it seems good in SITL.
But in real flight, the yaw of drone doesn’t change smoothly. It stops for a short time , and then turn maybe 10deg , different from the stable 10deg/s i test in SITL.But the time it takes to rotate 360deg is the same , all 35s.
below is my dronekit code:
from dronekit import connect, VehicleMode
import time
from pymavlink import mavutil
#mavlink消息需要至少每秒发送一次
def send_ned_yaw_rate(yaw_rate):
msg = vehicle.message_factory.set_position_target_local_ned_encode(
0, # time_boot_ms (not used)
0, 0, # target_system, target_component
mavutil.mavlink.MAV_FRAME_LOCAL_NED, # frame=1
1479, # type_mask=1479(忽略位置/加速度/偏航,启用速度/偏航率) 0b10111000111 使用速度+角速度
0, 0, 0, # x/y/z位置(被忽略)
0, 0, 0, # vx/vy/vz速度(未使用,但type_mask启用了速度字段)
0, 0, 0, # afx/afy/afz加速度(被忽略)
0, yaw_rate # yaw(被忽略)、yaw_rate=0.174 rad/s
vehicle.send_mavlink(msg)
def arm_and_takeoff(aTargetAltitude):
Arms vehicle and fly to aTargetAltitude.
print("Basic pre-arm checks")
# Don't try to arm until autopilot is ready
while not vehicle.is_armable:
print(" Waiting for vehicle to initialise...")
time.sleep(1)
print("Arming motors")
# Copter should arm in GUIDED mode
vehicle.mode = VehicleMode("GUIDED")
vehicle.armed = True
# Confirm vehicle armed before attempting to take off
while not vehicle.armed:
print(" Waiting for arming...")
time.sleep(1)
print("Taking off!")
vehicle.simple_takeoff(aTargetAltitude) # Take off to target altitude
# Wait until the vehicle reaches a safe height before processing the goto (otherwise the command
# after Vehicle.simple_takeoff will execute immediately).
while True:
if not(vehicle.mode == VehicleMode("GUIDED")):
break;
print(" Altitude: ", vehicle.location.global_relative_frame.alt)
#Break and return from function just below target altitude.
if vehicle.location.global_relative_frame.alt>=aTargetAltitude*0.95:
print("Reached target altitude")
break
time.sleep(1)
vehicle = connect("udp:192.168.4.2:14550", wait_ready=True)
print("drone connected")
time.sleep(1)
arm_and_takeoff(5)
print("Start to change yaw_rate to 10deg/s")
time.sleep(1)
for x in range(0,34):
break;
send_ned_yaw_rate(0.174)
time.sleep(1)
#vehicle.mode = VehicleMode("LOITER")
