I am very new to this and I have a remote mower I built 3 years ago & I want to build an Autopilot for it. I have the hardware setup and have been successful at everything so far… BUT I cant see the green bars on the Radio Calibration tab in Ardupilot Rover "MANDATORY HDWE "
I feel like the receiver /Transmitter are paired as they work fine for years without the Pixhawk from “radioLink"
I have double checked the wiring as " I UNDERSTAND IT” but I tried 4 different laptops and get the same result…
Does the USB cable have to be plugged in for this setup …or can it be done over 915 mhz telemetry radio?
thanks in n advance for any suggestions.
Thanks Kenny , My receiver does not support S-Bus as far as I can tell. I ordered another one that does & works with AT10 TRx. So I will throw parts at it til it works…
As for the case of your using Linear Actuators for your steering being slow to respond. Have you seen the wiper motor servos made with a bell crank or a cam to activate the steering motors on a ZTR mower?
Doug
Once I changed the configuration in the linear actuator control boards, I have had pretty good response. I still wonder about their longevity, though. It is a wait and see thing. But, I will look into the wiper motor servos idea for when I do replace them. Thanks.
I bought an S-Bus micro receiver and it seems to be working . I suppose the one I have with AT10 is not compatible with Pixhawk. There is a lot to learn on this. Thanks
Doug
