Can we On-Off LED ouput from Radio
Flight Controller:Matek H743-SLIM Flight Controller
For mapping please refer http://www.mateksys.com/?portfolio=h743-slim
I have installed “Panda RC WS2812 LED Arm Light” LEDs and works perfectly and change colour according to status.
How can I On-Off LEDs from Radio using any Switch?
You would need a relay controlled by an AUX output configured for a relay. The relay would need to interupt the 5volts supply to the LED strings.
Or there are PWM controlled switches available.
Use a flight controller output, not a direct connection the radio reciever - that way it is logged and you can control it with scripting if needed.
https://www.servocity.com/pwm-controlled-switches/
" D4184 Mosfet control Module Replacement Relay" this should work for me right?
https://www.electronicscomp.com/d4184-mosfet-control-module-replacement-relay
yes but you will need to configure the pin as a relay rather than pwm.
How can we configure individual Pin as GPIO?
I have 1-4 As Dshot1200,5-12as PWM and 13 as NeoPixel Led?
I want make 5 pin as GPIO
FC is Matek H743-Slim
@xfacta Can I request new feature to control Led brightness like VTX power?(NTF_LED_BRIGHT)
