Hi Ardupilot community,
Is it possible to connect two TFmini lidars on ArduRover through uart?
My end goal is to have obstacle avoidance with my rover. I have two TFmini’s mounted on the front of the rover, and have connected them both into Serial 4 & 5 (the 1 port) on my pixhawk 2.4.8. They are both powered up, i can see the red led light inside them. These are being powered over two ports. Can’t seem to make them work.
I have configured them in the Lidar manufacturer software, can’t think of the name off the cuff.
I haven’t connected into telem2, as i want to connect a computer into that port.
Can some confirm if this is possible with the setup i have described? If it can be, can you please articulate what settings i need to adjust. If not, can you suggest a different method?
I have search on the net and discourse but no joy, not even sure if i can do it yet or whether i need to attach these to a computer and have them communicate commands to Pixhawk.
Any information would be great.
Regards
Ben
My configuration:
Ardurover Firmware 3.4.2
MP 1.3.58.1 build 1.3.6841.9548
Pixhawk 2.4.8
Settings configured:
Serial 4 & 5 Protocol = 9
Serial 4 & 5 = 115
RGFND_ORIENT = 1
RGFND_FUNCTION = 0
RGFND_TYPE = 20
RGFND2_ORIENT = 7
RGFND2_FUNCTION = 0
RGFND2_TYPE = 20
