Can not setup Wireless Communication to pixhawk
I can not seem to connect Banggood’s FPV Radio Telemetry Ground Module to Pixhawk.
I have tried the drivers below where windows 10 says device is working properly but also says that the ‘Device could not be migrated’ (See images).
I have the air module connected via TELEM 1 on the Pixhawk. Both the ground module and air module display a solid green light.
After going around in circles for 6 hours on the web i have gained no progress.
Is this a windows 10 issue or driver issue or both ??
Are there any drivers out there that may work (Could not find any alternatives)
Drivers i have tried (Two different versions):
https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
Error Message after attemping COM7 - 57600
Attempt to connect with lower baud…which just times out after 30sec (Under 32374 from error message above).
