There was a setting in previous versions called Pilot_vel something and it seems it’s no longer in the parameters list. I need to increase the rate of climb while in PosHold mode.
PILOT_SPEED_UP and PILOT_SPEED_DN have replaced the old parameter, so you can now have different climb and decent rates.
Is that just for Stabilize, or also for loiter and PosHold…?
It doesn’t affect Stabilize at all. Throttle control will go from from “Plummet to Earth” to “Military Power” in Stabilize.
I changed it it just seems like it has a lot of expo in it but it does eventually get to a faster speed. Now how do you adjust the speed at which it accelerates?
PILOT_ACCEL_Z, all the info is in the wiki
You could try MOT_THST_EXPO
