Very interesting, thank you.
hello, I have the same plate that you got me yesterday the surprise was to put everything back and correct welding etc ⊠the drone does not start giving purple light and blinking ⊠what could it be?
Hello, i found out some approach that can help to change ArduCopter params via WIFI and Android cell phone. That approach doesnât require a SSH or USB connection to your drone.
It might be useful for those who want to change some parameters and continue use default app and doesnât want solder a USB connector to his drone.
Ok letâs begin.
As we know, EnjoFly can change some parameters of drone (if to be more precisely itâs maximum possible altitude and flight mode). Thatâs mean that app communicate with Drone with some protocol. After analyzing the APP-> Drone network traffic, i found out that APP send some data through 10005 UDP port.
These messages were MavLink packets, It can be recognized by marker byte 0xFE of each message (MavLink V1).
As we know, the UDP protocol doesnât require an establishing connection, thatâs mean we can send our data to this port, namely MavLink messages.
Main problem that we can faced with is how we can build a MavLink messages? Ofcourse we can write some packet builder, but there is some easier way to do that.
There is famous app named QGRoundControl. It understand and generate MavLink messages.
That all we need, just connect QGRoundControl to droneâs IP (by default 172.50.10.1) and 10005 port.
But itâs not that simple. Drone wonât communicate with QGRoundControl, until App (EnjotFly) verificate the Drone. (App probably initiate connection with drone).
In order to initiate MavLink connection, we just need:
- Connect to our Controller or Drone
- Launch the EnjoyFly
- Wait until the button says âStart Flyingâ
- Press that button
At this point, we have MavLinkâs opened port. Donât close the APP, just minimize it, and allow him work in background.
Then:
- Open QGRoundControl,
- Click to left-top purple button
- Choose from left menu âComm Linksâ and click to âAddâ
- In âTypeâ field, choose UDP.
- Now type in âListening portâ 10005 and in âTarget Hostsâ the droneâs (or controllerâs) ip (by default 172.50.10.1)
- And click âAddâ
Having added the new host, just choose it and click âconnectâ. After several seconds the app should connect to drone, and start read droneâs parameters.
If that didnât happend, probably the MavLink connection hasnât initiated by the APP (EnjoyFly). You should close all apps, reboot the Drone and start again.
If everything is OK, you should see the battery voltage, and some other parameters.
In order to change ArduCopter parameters, go to âSettingsâ and choose âParametersâ,and here is you can change droneâs parameters.
In this app you can choose the flight modes, or maybe launch some Mission (not tested).
In order to be ensured that parameters are applying, i changed the maximum droneâs altitude to 1500m. It located in Parameters -> Advanced -> PSC -> PSC_limit_alt (EnjoyFly permits maximum only 500m), then restarted the drone and launched EnjoyFly, and in Settings menu i saw 1500 meters.
WARNING!
These method has critical disadvantage:
If QGRoundControl lose connection with drone, you wonât able to control the drone anymore (even via EnjoyFly) until drone restarted, which is imposibble when drone in the air.
Therefore donât use QGRoundControl to control the drone instead of default app. It may cause drone lost.
This is a reasonable approach to setting some parameters, but there are indeed some issues to consider. First, the drone app appears to change some parameters on its own, and has an apparently fixed view of flight modes. For example, if you change modes via QGC, the app will not necessarily recognize them. Uploading a mission via QGC in this configuration is probably possible, but as the author above notes, losing your connection to QGC in that instance may mean loss of control (except perhaps from the drone controller itself, if youâre in a state where alterations of a mission are permitted by ArduCopter). Typically, the kind of simple parameter changes like landing speed, return to home altitude, etc. probably wonât be overridden by the app. For safe uploading of missions and full telemetry logs, use of a companion computer will likely still be required. My general view is that the less those apps are used at all, the better. Within the context of QGC there is full control over flight modes â e.g., you can configure so that the flight mode button on the controller will switch between normal loiter and loiter with simple mode (headless).
This approach works even when connected directly to the droneâs wifi, no actual need to use the controllerâs repeater wifi.
The UDP connection does need to be triggered by the C-FLY app otherwise QGroundControl doesnât seem to be capable of connecting to the drone.
Overall itâs a very useful non-intrusive method to modify most of the parameters, just make sure you know what youâre doing, and definitely donât do this while the quad is in the air.
Iâve successfully used this method to change the RTL_ALT to 0, so the quad will no longer climb to 30 meters before heading to its take off location, very useful if you are low on battery. Has some drawback, if there are obstacles between the quad and the home location then obviously you have to cancel the RTL.
Other that that Iâve changed the CIRCLE_RATE which was set to 20 deg/sec and this was horrible, the resulting video was awful, now Iâve changed it to 6 deg/sec so a full panoramic turn will take 60 seconds, more if you increase the radius with the right stick.
So overall a very useful method. I havenât yet managed to connect to Mission Planner on my PC but will give it some more careful tries soon.
The only problem with QGC is that thereâs no way to account for the customizations done to the PX4 thatâs running on these quads. When I connected to it, there were some warning messages that some channels were set or not set, some other params not set and such. I did not touch those since I have no idea how the app sets those. But the âusual suspectâ RTL_ALT being chief among them, can be set easily and are persisted between reboots of the quad. The app doesnât seem to have any way to set those so the ballpark guideline is âif you canât change it from the app then it probably wonât be changed at allâ, But of course this depends on the parameter. Switching modes using the M button might be interesting if you can afford a runaway but most folks donât experiment with their quads which they expect to fly like a DJI Mavic Pro and cost as much as a pack of smokes⊠sarcasm showing up here
The biggest customizations that their PX4 build seems to have (other than assorted parameters set to other than the more typical defaults) seem to relate to anything needing an sdcard â since the unit has no sdcard. So logging, retaining missions between boots, etc. appear to be compiled out and most of the related parameters do not exist. QGC complains mostly about the unit not having multiple compasses and such.
hmâŠthen I wonder how are the gimbal and camera controlled? I know the live video stream is an rtsp feed but other than thatâŠ
The still shot/video/gimbal up/down movements are controlled by auxiliary RC channels. However, in a cursory examination some time back, I didnât find the expected configurations in the ArduCopter settings for those channels. So either I missed them (which is possible, I didnât look in depth) or theyâre being routed directly in the build. When you monitor the RC channels directly (e.g. in QGC or Mission Planner), you can see how the PWM changes for those functions.
I know there are MAVLink messages to control gimbal movement as well as still/video recording so theoretically this should be possible to figure out from how the controller outputs are recorded by the drone, what reactions they cause, the one thing I believe would interest more people is if there is a way to change the camera settings such as ISO, shutter speed, exposure, that sort of thing, even if it is just on a regular UVC device capable level, that I think should give some flexibility although I believe it would be rather difficult to integrate into the controlling app without its source code.
The other thing I was rummaging about was the ANGLE_MAX and the PHLD_BREAK_ANGLE which would mean we can increase the max speed and reaction time of this quads, leading to better resistance to stronger winds and the obvious extra speed which some people complained about. y default these seem to be set to 20 deg so I was thinking to make it 25 deg but Iâm not sure I could gauge if this small increase was useful without risking the drone flying away. I know the biggest value I could/should set is 45 deg, but this as far as I can tell affects the camera and gimbal: the camera will reach its maximum range of motion if greater than 25 deg. On the other hand, Iâm not sure the gain would justify the risk of changing from default, after all whoever made this quad did (hopefully) some testing and tuning to set those params.
Remember that there are differences between Loiter mode and Position Hold mode relating to handling. The drone defaults to Loiter and canât change to Position Hold unless the flight mode parameters are altered.
Good point. I did notice there are several âangle maxâ params in the documentation so looking at ANGLE_MAX: Angle Max
Note: This parameter is for advanced users
Maximum lean angle in all flight modes
Now it says ALL FLIGHT MODES but then thereâs this:
LOIT_ANG_MAX: Loiter Angle Max
Loiter maximum lean angle. Set to zero for 2/3 of PSC_ANGLE_MAX or ANGLE_MAX
and this:
PHLD_BRAKE_ANGLE: PosHold braking angle max
PosHold flight modeâs max lean angle during braking in centi-degrees
So I figure it would be up to an actual test to see how and which ones to set. Obviously setting all to the same value would be the simplest choice to ensure all modes use the same max lean angle value but this could become quite cumbersome to keep track and not miss something.
But then again, itâs for experimentation so might as well leave it as it is for now and only go for a change if the âitchingâ gets worse
hello,
Iâve been watching this topic since i got my hands on the X12 not so long ago. so i tried to connect to it using this method you share. i connected directly to the aircraft wifi and got this warning
so my question is, what did i do wrong?
Just ignore that message. Itâs just a warning about parameters not supported in the device. Close the warning and move on.
thank you for the reply.
one more thing thoâ any tips to keep the aircraft connected because it keep turning off after a while and its quite annoying.
Yeah, thatâs a big downside to this approach vis-a-vis my favored USB approach. When I tested the unit early on, the only way (without being connected to USB) that I found to keep the unit from powering off after some small number of minutes was to arm it at intervals. When connected by USB the unit never self powers off. More detail: If you connect USB without a battery in the unit, you can access and change all parameters. No timeouts or other problems. If you connect USB with a battery in the unit, you have that same access plus the unit will immediately power on fully and stay on unless you manually turn it off.
I am using SiK telemetry radios to connect QGC on Android to my Pixhawk and F405-Wing.
Behaviour is the same as using USB.
Can you connect to a serial port?
https://www.rcgroups.com/forums/showthread.php?3374105-Connecting-SiK-telemetry-radio-to-F405-Wing
You can connect a SiK radio via a companion computerâs serial port (definitely works), but otherwise no.
how difficult is it to fashion a USB interface cable for it?
If you look up at the early part of this thread, youâll see how I did it, since at the time the proper parts were not easily available. It was not fun. I now have the proper connectors with already installed conductors, but I have not used them on the unit because the current ad hoc version is still working and cleaning it up to accept the correct connector would be a significant (and possibly unsuccessful) effort. One note, even if you do use the correct connector and conductors, it is essentially impossible to get the conductors out past an installed battery without damage, This means that â like with my ad hoc version â you really need to drill a flush hole out the side. This must be done very carefully, since one of the antenna coax lines runs directly through that area and could be easily damaged.
