i see binary output in build//bin directory, but i would like to have elf (with debug symbols), how does one build the output in .ELF in addition to .BIN ??
how do you add -g gdb in the $CC command to generate debug infoatmion ?
thank you for the info… i did real the document, but ran into
issue
when i did the following as i understood from the build
instruction
./waf --debug --board
./waf --vv coptor
i got the following error
../../libraries/AP_ROMFS/AP_ROMFS.cpp: In static member function
‘static uint8_t* AP_ROMFS::find_decompress(const char*,
uint32_t&)’:
…/…/libraries/AP_ROMFS/AP_ROMFS.cpp:57:58: error:
‘compressed_size’ may be used uninitialized in this function
[-Werror=maybe-uninitialized]
const uint8_t *p = &compressed_data[compressed_size-4];
compilation terminated due to -Wfatal-errors.
cc1plus: some warnings being treated as errors
then i thought perhaps i misunderstodd the instruction and tried
./waf --board
./waf --debug --vv coptor
there was no error building ardupilot, but the resulting elf
file does not have debug information (and the gcc did not have -g
gdb)
so i am not clear how to generate elf with debug information ???
i am seeing some strange issues, but maybe my total misunderstanding the whole structure of the software.
first of all, is the bootloader necessary ? if i am not interested in mission planner or other things, just want to use st-link for flash my software to control sensors and escs … do i need bootloader ?
perhaps thats my issue, without usign bootloader, and the ardupilot crashses rightaway…
the tool i am using is gcc-arm-none-eabi-6-2017-q2-update… (i found that 2018-q4-major does not work).
also, notice very strange issue… i create my new board and copied files from F4BY (just to see what happen)… it successfully built with “waf --configure myboard”, but if i did “waf --configure myboard --debug”, then it failed to compiled. the strangest thing is that if i did “waf --configure F4BY --debug” it works fine, even though two directories have exact the same files.
also, the documentation maybe outdated regarding porting to a new board, because i think (at least from my poking around), i would need to add board name to Tools/scripts/build_binaries.py and also, add new ID in libraries/AP_HAL/AP_HAL_Boards.h
i got the waf from cloning ardupilot, on the top directory
i am using a STM32F407 discovery for now, just to get familiar with Ardupilot, before going to custom board, so it is not possible to brick the bard as st-link is available to recover
i am just curious how is that when simply renaming the board would make the waf fail, and adding --debug would also fail the build process
(not getting as far as chaning I/O yet because build (waf) did not even finish
