File “Tools/ardupilotwaf/uavcangen.py”, line 24, in run
input_dir = os.path.dirname(self.inputs[0].abspath())
IndexError: list index out of range
It worked 3 days ago, and I can’t find any changes in the code. I’m sure it’s my environment but have no idea where to look. Any help at all is better than I’m doing. This is a build against a fresh git clone . There is an open issue but no comments made to it.
I can’t remember the exact fix, but it was either checkout, then run git submodule update, then run ./waf distclean. i think it was caused by checking out an older version. I assumed you only had to update submodules when cloning the repo, but you need to do that after a checkout too.
