Hi
I am trying to build using waf on mac os monterey
I configured it as ./waf configure --board CubeOrange
when calling ./waf bin
it fails with this output
Waf: Entering directory `/Users/macbook/Documents/Development/Flight Control stuff/ardupilot/build/CubeOrange’
Checking for env.py
env added OPTIMIZE=-O2
env added BUILD_ABIN=True
env added ENABLE_DFU_BOOT=1
env added WITH_FATFS=1
env added WITH_NETWORKING=False
env added PROCESS_STACK=0x1C00
env added MAIN_STACK=0x600
env added IOMCU_FW=0
env added PERIPH_FW=0
env added HAL_NUM_CAN_IFACES=2
env added HAL_CANFD_SUPPORTED=8
env added BOARD_FLASH_SIZE=2048
env added EXT_FLASH_SIZE_MB=0
env added INT_FLASH_PRIMARY=False
env added ENABLE_CRASHDUMP=True
env appended APP_RAM_START=None
env appended CPU_FLAGS=[‘-mcpu=cortex-m7’, ‘-mfpu=fpv5-d16’, ‘-mfloat-abi=hard’, ‘-DARM_MATH_CM7’, ‘-u_printf_float’]
env added CORTEX=cortex-m7
env added APJ_BOARD_ID=140
env added APJ_BOARD_TYPE=STM32H743xx
env added USBID=0x2dae/0x1016
env added FLASH_RESERVE_START_KB=128
env added EXT_FLASH_RESERVE_START_KB=0
env added FLASH_TOTAL=1966080
env added HAS_EXTERNAL_FLASH_SECTIONS=0
env added DEFAULT_PARAMETERS=/Users/macbook/Documents/Development/Flight Control stuff/ardupilot/build/CubeOrange/processed_defaults.parm
env added CHIBIOS_BUILD_FLAGS=USE_FATFS=yes USE_LWIP=no CHIBIOS_STARTUP_MK=os/common/startup/ARMCMx/compilers/GCC/mk/startup_stm32h7xx.mk CHIBIOS_PLATFORM_MK=os/hal/ports/STM32/STM32H7xx/platform.mk MCU=cortex-m7 ENV_UDEFS=-DCHPRINTF_USE_FLOAT=1
Padded 20 bytes for bootloader.bin to 17856
Embedding file bootloader.bin:/Users/macbook/Documents/Development/Flight Control stuff/ardupilot/Tools/bootloaders/CubeOrange_bl.bin
Embedding file hwdef.dat:/Users/macbook/Documents/Development/Flight Control stuff/ardupilot/build/CubeOrange/hw.dat
Embedding file io_firmware.bin:Tools/IO_Firmware/iofirmware_highpolh.bin
Embedding file io_firmware_dshot.bin:Tools/IO_Firmware/iofirmware_dshot_highpolh.bin
[ 4/11] Creating build/CubeOrange/modules/ChibiOS/include_dirs
[10/11] Processing /Users/macbook/Documents/Development/Flight Control stuff/ardupilot/build/CubeOrange/libraries/AP_Scripting/lua_generated_bindings.cpp,/Users/macbook/Documents/Development/Flight Control stuff/ardupilot/build/CubeOrange/libraries/AP_Scripting/lua_generated_bindings.h: libraries/AP_Scripting/generator/description/bindings.desc build/CubeOrange/gen-bindings → build/CubeOrange/libraries/AP_Scripting/lua_generated_bindings.cpp build/CubeOrange/libraries/AP_Scripting/lua_generated_bindings.h
/bin/sh: Control: command not found
Waf: Leaving directory `/Users/macbook/Documents/Development/Flight Control stuff/ardupilot/build/CubeOrange’
Build failed
→ task in ‘/Users/macbook/Documents/Development/Flight Control stuff/ardupilot/build/CubeOrange/modules/ChibiOS/include_dirs’ failed (exit status 127):
{task 4369671536: /Users/macbook/Documents/Development/Flight Control stuff/ardupilot/build/CubeOrange/modules/ChibiOS/include_dirs → include_dirs}
(run with -v to display more information)
