Hello everyone,
i am currently working on building a skid steering rover,but i am definitely missing something here.It is a skid steering vehicle and it needs to relay pins to work properly,so i read that the default relays are relay1 and relay2 ,after making all the connections i tried auto mode to see what happens,but there is no response from the relays,therefore i am trying to find a solution on how to enable the two relays,from mission planner without having to give the command from the RC controller,
Thank you !
Hi Manos, are you able to give more details so people can help?
In my ArduRover 4.0 setup relay1 and relay2 are mapped to AUX 5 and 6 by default. Is that how you have the wires connected?
I have this same issue! Are there any updates on this?.
I have my motor direction wires connected to aux 5 and aux 6, but do not get any voltage when doing motor test in reverse (negetive value). Any suggestions?
