Im tuning my copter, and Im not clear what part of the tunning PID can help me to fix this. As you can see in the video (Loiter), when I move side to side, or front to back, when I release the stick, the drone keep moving and 1 or 2 seconds,and then, the drone brakes to get stady.
How can I do the drone do that brake as soon as I release the stick?
Thanks!
http://robomotic.dyndns.org:16211/archivos/Videos/braking.MOV
ekliptiko
September 16, 2019, 10:59pm
2
Have you tried PosHold flight mode?
Ive been trying to tune my copter like you describe and I found that I had better consistency with PosHold.
Here is some good info:
http://ardupilot.org/copter/docs/loiter-mode.html#tuning
Edit: Also this (its been a while since ive looked at this in particular, my memory is slowly coming back now that im reading about it again, haha):
http://ardupilot.org/copter/docs/parameters.html#loit-brk-delay-loiter-brake-start-delay-in-seconds
LOIT_BRK_DELAY: Loiter brake start delay (in seconds)
Note: This parameter is for advanced users
Range
Increment
Units
0 - 2
0.1
seconds
http://ardupilot.org/copter/docs/parameters.html#loit-brk-accel-loiter-braking-acceleration
LOIT_BRK_ACCEL: Loiter braking acceleration
Loiter braking acceleration in cm/s/s. Higher values stop the copter more quickly when the stick is centered.
Range
Increment
Units
25 - 250
1
centimeters per square second
I have no idea what the default is - but start by checking LOIT_BRK_DELAY, then check LOIT_BRK_ACCEL
great!!! thats seems the solution! I will try it!
Thanks!!
lixiaowei
(lixiaowei)
September 1, 2022, 3:53am
4
I think loiter
The braking mode should be optimized
xfacta
(Shawn)
September 1, 2022, 7:25am
5
Try these
LOIT_ACC_MAX,600
LOIT_BRK_ACCEL,300
LOIT_BRK_DELAY,0.3
LOIT_BRK_JERK,300
