My poor Edison has been cut from power many many times as I reboot the pixhawk and eventually it stops booting.
This is what I can see via the serial interface:
[FAILED] Failed to start WPA supplicant.
See 'systemctl status wpa_supplicant.service' for details.
[ **] A start job is running for /etc/rc.local Compatibili... 8s / no limit)
An apsync reinstall gets it working fine but if anyone knows a way to fix it in the field, that would be much better. I don’t want the Edison stopping or delaying an otherwise well-planned mission.
I would like to ssh and shutdown the edison nicely but that’s sometimes not possible.
Make sure you’re not running short on “disk” space?
I think I’ll have to change the way I upgrade and configure the p2 to include an Edison rebuild after all the calibrations, reboots, field tests have been done. I may also disable wpa_supplicant so that it’s not a risk in the field. I can still connect via serial console and start wifi if needed. Currently it’s only used for scp log downloads and the initial dronekit setup.
It’s unfortunate that I can’t get to see syslog to actually see what the issue is.
Update: I’ve implemented logrotate on /var/log/syslog|messages|kern.log because these were growing to >100M. Now they are compress and it removes older files. Some of my missions are more than 4 hours long so a single mission can fill the root filesystem.
