BOOST Function with Turbines
Hi
I would like to try using the BOOST function with a single gas turbine mounted underneath a quadcopter. The issue is that turbines require the throttle stick to go from IDLE to FULL Throttle momentarily to initiate the start sequence. Once started it will go into IDLE. Can this be achieved using the BOOST function in its current form?
I see RC Auxiliary Function (“161”) is available for Heli’s? Can it be used on Quads too?
Any tips would be appreciated.
Thanks
Mark
