Hello, I am building a new dual motor plane and after configuring the dshot setting I had passthrough working and reflashed the esc. Then went back into mission planner probably changed some random setting and now I can’t get passthrough working again giving me an error no active motor outputs found. I am fairly certain that the flash went ok with the esc because the motor still do the normal startup beeps and the spin just fine, just the blheli 32 suit will not even try to connect. any help would be appreciated
I ended up reflashing the flight controller and doing a ton of other stuff and that fixed it, but I believe the problem was to do with servo outputs 7 and 9 sharing a timer and one was set to dshot while the other had a normal servo.
