davidae
(David)
April 8, 2021, 5:47am
1
Hello!
I am with the telemetry configuration of my new ESC Tekko 32 65A metal 4 in 1, all the motors work ok with Dshot150 but the only way that the ESC sends telemetry to the Pixhawk The Cube Black is when I activate the “Auto telemetry ON” in BLHeliSuite, if not, there is no data. Here is my configuration:
And the telemetry port configurated is the Serial4
There is something that I am doing wrong, but I don’t know it.
Thanks!!
andyp1per
(Andyp1per)
April 8, 2021, 10:47am
2
Try settig the debug parameter and see what output you get
davidae
(David)
April 8, 2021, 11:38am
3
Hi @andyp1per
I have set that parameter and SERVO_BLH_TEST to 1 to test first motor, and this is the output:
andyp1per
(Andyp1per)
April 8, 2021, 1:32pm
4
How are you telling whether you have telemetry or not? Its only supported on mavlink2 so you need to make sure your GCS setup supports that
davidae
(David)
April 8, 2021, 5:02pm
5
Because in the “status” tab in the latest Beta of Mission Planner I can see the temp and voltage of the ESCs if I activate the option “Auto telemetry on” in BLHeliSuite. But if that option is disabled, all that information is 0.
andyp1per
(Andyp1per)
April 8, 2021, 5:07pm
6
So make sure that SERIAL0_PROTOCOL is set to 2
davidae
(David)
April 8, 2021, 5:14pm
7
Yes, that is correct, serial0_protocol is set to 2
RainFly
(RainFly)
April 8, 2021, 5:21pm
8
RCOut is PWM1-12.
I thought DSHOT is needed for BLHeli telemetry,
Try to set SERVO_BLH_MASK
andyp1per
(Andyp1per)
April 8, 2021, 6:17pm
9
Yes indeed, or set MOT_PWM_TYPE to 4-7
davidae
(David)
April 9, 2021, 5:30am
10
andyp1per:
MOT_PWM_TYPE to 4-7
That solved the problem, now MP shows RCOut: PWM:1-8 DS300:9-12 and when I push the safety switch, the telemetry appears.
So thank you very much @RainFly and @andyp1per for your help.
And I didn’t see that parameter in the wiki (https://ardupilot.org/copter/docs/common-dshot-blheli32-telemetry.html#connecting-your-escs-for-use-with-dshot-protocol-and-blheli-32-features ) so I think that it would be a good idea to make a mention of that.
MrNams
(MrNams)
December 2, 2021, 12:43pm
11
Even after this change its not working for me
I have
Flight Controller:Matek H743-SLIM
ESC:T-Motor P50A 3-6S BLHeli_32 4-in-1
Parameters i set are MOT_PWM_TYPE=6 //DShot600 SERVO_BLH_AUTO=1 SERVO_BLH_MASK=0 SERVO_BLH_OTYPE=0 SERIAL5_PROTOCOL=16 //ESC Telemetry BAT_MONITOR=9 //ESC
Also sharing complete parameters
Shared with Dropbox
andyp1per
(Andyp1per)
December 2, 2021, 1:27pm
12
Your settings look right to me - maybe check the wiring? I have a very similar ESC with that FC working fine
MrNams
(MrNams)
December 2, 2021, 1:28pm
13
I have been flying it with iNav for last one month, switching to Ardupilot and facing these issues, i solved all other issues only this is remaining
andyp1per
(Andyp1per)
December 2, 2021, 1:29pm
14
Ok, what is not working? Please also share your BLHeli settings
andyp1per
(Andyp1per)
December 2, 2021, 1:44pm
16
And what do you observe that means its not working?
MrNams
(MrNams)
December 2, 2021, 1:52pm
17
Its not showing battery voltage and current
MrNams
(MrNams)
December 2, 2021, 1:53pm
18
Can you share your params?
andyp1per
(Andyp1per)
December 2, 2021, 1:56pm
19
Does it show RPM?
Here are params from a copter flying with Lumenier HD Lux and T-Motor F55Pro F3
Chimera7-Tuned4.1-FinalCut.param (25.7 KB)
Are you using 4.1? You should be.
