Try the beta version of mission planner
Its beta only, now updating latest beta
If rpm is working and you are not using bdshot then it is working and must be some kind of GCS issue
02-Dec-2021 08:04:15 PM : Frame: QUAD/X_REV
02-Dec-2021 08:04:15 PM : IMU0: fast sampling enabled 8.0kHz/2.0kHz
02-Dec-2021 08:04:15 PM : RCOut: DS600:1-4 PWM:5-6
02-Dec-2021 08:04:15 PM : MatekH743-bds 003D002C 32305119 3331393
02-Dec-2021 08:04:15 PM : ChibiOS: 45395b6a
02-Dec-2021 08:04:15 PM : ArduCopter V4.1.2-rc1 (d6a4cc6f)
02-Dec-2021 08:04:14 PM : Frame: QUAD/X_REV
02-Dec-2021 08:04:14 PM : IMU0: fast sampling enabled 8.0kHz/2.0kHz
02-Dec-2021 08:04:14 PM : RCOut: DS600:1-4 PWM:5-6
02-Dec-2021 08:04:14 PM : MatekH743-bds 003D002C 32305119 3331393
02-Dec-2021 08:04:14 PM : ChibiOS: 45395b6a
02-Dec-2021 08:04:14 PM : ArduCopter V4.1.2-rc1 (d6a4cc6f)
But at least it should show in OSD, it is not showing in OSD as well, literally struggling for last 2-3days
I just loaded up a slim with the same firmware as you and connected to a F55A Pro II:
Parameters:
param-set.param (19.9 KB)
From where these values come
BATT_VOLT_PIN=10
BATT_CURR_PIN=11
They are the defaults for the board. I wiped the parameters and these were set automatically. If you set FORMAT_VERSION=0 you can reset all the parameters.
Many many thanks, while comparing with your parameters i got clue on BATT_VOLT_PIN and searched same and got to know from one of post by @xfacta Shawn that,
ESCs dont output current in the telemetry , the 4in1 has onboard analog current sensor.
so setting BATT_VOLT_PIN=10
BATT_CURR_PIN=11 it started showing voltage, but curret it shows incorrect.
If you look at my current calibration in the Chimera parameters above this is the result of a very careful calibration that will give accurate results above 3A but inaccurate results below that.
Thanks, are these PID values fine tuned?
For that frame, weight, battery, ESC and motor combination - yes
