I need all the help i can get here. I have another thread from a couple years ago talking about a very similar issue. Now i have basically fully rebuilt this UAV and now i have a similar problem. The motors just don’t run right, like the config for each is different.
Using an orange cube, and luminaire Elite 60amp 4 in 1 ESC’s. The ESC is hardly used at all, its never really flown with this ESC. Latest Mision Planner and BLHeli.
So i downloaded and installed BLHeli Suite to try to check the configs of the individual ESC’s. Here are the rersults;
Trying to flash fails every time. Flashing 3 and 4 worked just fine, so seems passthrough is working fine. I pulled my wire harness tht goes from Cube to ESC out all the way and fully inspected and tested it for continuity, and it seems fine. Im pretty good at wiring, so this was simply to cover bases. I ordered a new ESC, but wont get it for several days.
What sucks is this ESC is basically brand new, seems like the firmware on it is just broken. Any help would be appreciated. Any way to force a firmware onto them?
Thats why i bought a new one. Seems this one is toast. Problem is even though its barely used, i did purchase it over 2 years ago, so return not an option.
Should also mention that even though #2 doesnt show, all motors spin, its just obvious not at the same speed.
I ran into some strangeness like this before, but I can’t for the life of me remember what I did. Are you using the main channels on the cube or the Aux channels?
I’m reasonably sure passthrough will work on main, but not bdshot. I know there’s been some people experimenting with bdshot on the main outputs but I don’t know if that’s gone mainstream yet.
There will likely be 10 clones popping up in the next weeks and months*. Never really liked the fact that it was closed source anyway although I understand the people need to earn a living.
So got my new ESC. I installed it, and initially got the same result. 1 was unknown, 2 didn’t read at all. then I moved motors to Aux 3-6, configured appropriately, and boom they all four showed up. Motor tests are much more consistent.
So it seems the first two Aux channels on my Cube might be messed up for some reason. Question is, is my first ESC really toast. I’m not going down that rabbit hole right now. Spent all night soldering up the new one.
Now if only i knew how to clear this ‘CrashDump data detected’ error, i could arm.
