Hello everyone
I constantly check vibrations on similar copters using this method:
Average vibrations for the entire flight based on Vibe data.
Maximum vibrations for the entire flight based on Vibe data.
I read in the vibration section on https://ardupilot.org/ that vibrations higher than 15 are undesirable.
Question 1: Does this refer to the average level or the peaks or the frequency of such peaks?
Furthermore, after collecting statistics for some time, I had vibration levels on the Z-axis ranging from 13 to 16.
Lately, these indicators have often exceeded 20 - the average level for the entire test flight. This concerns me, even though I can’t find any problems in the design or assembly.
Question 2: There is a test TestVibration.py in the Mission Planner codebase. When I run it, I often get “Good Vibration” even if the average value for VibeZ in my statistical table is above 20, and the maximum values are higher than 60. Another question about TestVibration.py: why are we only checking the data recorded in Loiter, and AltHold is ignored? I just want to understand the logic.
I would be immensely grateful for an explanation of which method of checking vibration levels is best for filtering out copters. Based on IMU AccX… or based on Vibe…
Thank you very much in advance.
