I’ve purchased a Benewake TFMini Lidar. I’ve updated the firmware of my quadcopter to the latest release 3.6.7 and connected the lidar to the serial 4/5 port of my pixhawk. When trying to set it up, I’ve noticed that the RNGFND_TYPE 20 is not in the list.
At the moment, the lidar is not working. In the status windows its readings are 0.
I’ve connected the TFMini to the PC with a USB adapter and tested it with the Benewake GUI. The sensor works. I’ve then configured it in PIX Mode with the serial commands. I’ve connected it to the PixHawk through the Serial 4/5 port but the issue still remains. The TFMini is not shown in the list of available RangeFinders.
I’ve updated to the beta version of MP. Now I see Bad LiDAR Health on the Graph but still no readings in the Status Tab. Furthermore, under Optional Hardware > Range Finder now the list is completely empty. All Range Finders are gone. Tried to set to 20 in the Full Parameter List but no luck.
I’ve also tried to reinstall MP, both latest and beta versions. Range Finders list doesn’t appear anymore in both cases.
There’s something I’m doing wrong???
Very unhappy as the lidar works and it has shown as supported on the pixhawk…
How the TFMINI is connected to the pixhawk ?
How the TFMINI is powered = Pixhawk or dedicated UVEC wit common ground ?
How is Mission Planner is connected to the pixhawk ?
the TFMINI is connected and powered to the PixHawk through the Serial 4/5 port. I connect to Mission Planner via USB. In attachment there are 4 photos. There are:
Your USB port may not have enough power to operate both the pixhawk and the tftmini. Power the separately with a common ground. Or use a powered usb hub.
I’ll try to reverse the rx/tx lines although they reflect the scheme on the pixhawk wiki (so thay should be correct). The baud rate I’m using for serial 4 is 115 (115200) and the parameters are as follows:
SERIAL4_PROTOCOL = 9 (Lidar)
SERIAL4_BAUD = 115 (115200 baud)
RNGFND_TYPE = 8 (Currently - Tried 20 but had same result)
I’ve rewired the sensor and it finally worked. Probably there was a loose connection with the pins.
Tried in my room and the ALT_HOLD is super consistent. I’m so happy!!
