Hey guys, I setup my TFmini according the wiki, but sonarrange is still at 0. I have tried putting the TFmini wires on both the i2c ports and uart 4, and even swapped the wires when the range finder did not work. I know the range finder is receiving power because I measured the pads and the range finder is getting warm. Do you guys have any ideas?
Me im using the tfmini S…can you give more specs about your wiring?
As i know there are few versions of the Tfmini that you need change the add using the gui…with mine i dont need…
I have ground to ground and 5v to 5v on the flight controller, and I know it is receiving power. The green wire is connected to the SCL port, and the white wire is connected to the SDA port on the flight controller.
ok…me first time i’ve choose the serial port…after this on a can node…
for uart: 5v to 5v or (ubec), gnd -gnd , white is TX , green is RX
Did you check with benewake gui?
I did not check with Benewake GUI. How do you do that? I have also tried serial port and that does not work. I am pretty sure that my tfmini is i2c protocol.
