Battery recommendaitons from aliexpress or yandex market
I experience issue to find out the right battery for my copter. The description of the product doesn’t pass ballpark analysis. Could you please share your links on products you trust?
There are plenty amount of options on aliexpress.com or wildberries.ru, but I faced with their statement on current supply doesn’t match with battery capacity they use in the cell.
Aliexpress or wildeberries are the most convenient platforms for me, but if you could recommend a product which trusted seller is only on Amazon, it could be acceptable too.
Drone weight 3,5 kg including battery, motors thurst 7.2 kg, 120A (140A with some cap) of current consumption at max, expected flight time on maximum power 30+ minutes. I was thought of 6s battery with 12 000+ mAh. I will appreciate your recommendations.
