Battery Monitor missing parameters 3.8.1
Upgraded from 3.8.0 to 3.8.1 but it will not store the parameters for Sensor Type. When I set it to 7: ProfiCNC and switch to another tab and back, Mission Planner resets to 0: Other.
So I thought I’d use the Other sensor and set the measured voltage but that does not seem to update the voltage mulitplier.
I’ve reset all parameters, loaded Rover and then back to Plane but no luck. Power monitor was working on 3.8.0.
Anyone any ideas?
