Hi everyone. I have some problems with battery monitor setting up. Every time I tried to change the parameters I got “Set BATT_AMP_PERVOLT Failed” and “Set BATT_VOLT_MULT Failed”. Also, some parameters such as BATT_CURR_PIN and some others are missing.
You have to set the power sensor as analogue before you can see any of those parameters.
how can i do that ? do i need to change any parameters
Sorry I also had the same issue.
what board is it your using?
I am using pixhawk 2.4.8 board
It has suddenly started to work with all my setup. All I had to do is to restart my laptop, thank you
