failsafe
(failsafe)
October 7, 2022, 5:55am
1
I have an issue with battery failsafe not being triggered on my quad. The battery monitor and other parameters are set correctly. Once the voltage goes below the BATT_LOW_VOLT, mission planner voltage display turns Red, but does not switch to any of the failsafe modes even if the voltage drops 1V below the failsafe voltage.
CubeOrange
ArduCopter V4.2.2:
BATT_LOW_VOLT,20
BATT_LOW_TIMER,10
BATT_LOW_MAH,0
BATT_FS_LOW_ACT,1
BATT_FS_CRT_ACT,0
MOT_BAT_VOLT_MAX,25.2
MOT_BAT_VOLT_MIN,18.0
Thanks
xfacta
(Shawn)
October 7, 2022, 7:09am
2
Use MissionPlanner initial parameters page to set all them correctly.
Provide the .bin log
failsafe
(failsafe)
October 7, 2022, 7:30am
3
I have used the initial parameters page to set the values. Attached is a log.
First of all, update to ArduCopter 4.2.3. BATT_LOW_TIMER will introduce a 10 second delay
failsafe
(failsafe)
October 7, 2022, 7:45am
5
I waited 2-3 min after the low voltage level is reached but the failsafe was not triggered. I will update to 4.2.3 and check.
failsafe
(failsafe)
October 19, 2022, 2:37pm
6
Updated to 4.2.3 and tried different BATT_LOW_TIMER values but still it does not change the flight mode to LAND or RTL at failsafe.
xfacta
(Shawn)
October 19, 2022, 7:43pm
7
Please post a .bin log of that
