Hi guys, I would like to ask if anyone did experience this battery failsafe with no dropdown list appears, if so, how did you fixed this? Thanks.
Send a screenshot of power module configuration
Hi Sirm thanks for you the reply. In case someone has the problem problem like mine, I already fixed this. For ArduCopter Version 3.6 up, you need to set the BATT_FS_LOW_ACT on the parameter list. 1-Land, 2-RTL.
i’m also facing the same issue with mission planner version 1.3.74 with missing battery fail safe drop down list.
configure using full parameter list. however hope this can be fix and select from the drop down box.
Yes.
I’m using old APM2.8 and firmware of 3.2.1. The battery failsafe doesn’t show any drop down content for selection.
Why did you post in the 3.6 thread?
Retire that unsupported Flight Controller and replace it.
