Does esc calibration needs to be done for fixed wing? What does it do? Also, How does the autopilot know the end points of esc?
Also i want to know how can we setup ampere per volt in our battery monitor in optional hardware options and please explain it also:thinking:
ESC calibration is telling the ESC the expected range of inputs.
Current sensor calibration procedure is described in the documentation.
cbf123
(Chris Friesen)
3
Also worth noting that if you use ESCs that understand DShot, then you don’t need to calibrate them.
