I installed a PX4flow and Leddar One on my Cube powered quad. I followed all of the instructions. So far the rangefinder seems to work and shows data under sonarrange. The optflow only shows 0s. Any idea what I’m doing wrong? I’m on RC12 and the latest beta of MP.
Have you done the calibration step and checked if data flash logs have optical flow data, and compared it with gyro value yet? It will make sure that your Cube can read the flow sensor.
One notice is that after you enable optical flow in Mission Planner, you need to restart the Cube to make it work with PX4Flow. If possible, you should try the calibration step again and upload the log here so that I can help you find the problem. Good luck.
Should the PX4 status LEDs light up when plugged in via I2C? They light up when I plug in via USB, but don’t seem to light up when plugged into the I2C.
I think it was a faulty unit. I have 5v on my I2C but the PX4flow wouldn’t seem to power off of it. I tried to power it from USB while plugged into I2C, and it fried it
