Ostro
(Ido Ostro)
May 25, 2021, 8:39am
1
Hello everyone!
I’m trying to set up precision landing with IR Lock and Rangefinder
I tried to set up the “TFmini” threw the TELEM2 PORT and also tried to set up the “Maxbotix I2C EZ4”
on both of this setups (separately) I get a “Bad LIDAR Health”
I checked the wiring and everything looks good…
What can I do to make it work?
I’m using
CUBE (black) autopilot
ArduCopter V4.0.7
Many Thanks
Did you lift the copter above one meter before arming, like described in the wiki?
Ostro
(Ido Ostro)
May 25, 2021, 10:03am
3
Yes, I did try it, also the Sonar Range doesn’t react to any movement and the “Bad LiDAR Health” is alerting at the moment I connect the Drone to MP
Make sure the lidar is powered, and that the connections are correct
Ostro
(Ido Ostro)
May 25, 2021, 12:04pm
5
That’s was the first thing I checked of Corse…
Also I tried a different sensor and have the same issue so I thing its something else…
