Autotune P and I Values the Same (?)
Need some advice: I’m running ArduCopter v3.6.8 on a 680 H4 frame with PixHawk4 (https://rotorbuilds.com/build/18468).
Maiden Flight: I used default PIDs and it flew well. Downloaded and looked at logs as described in the “First Flight with Copter” section of the doc (LOG_BITMASK set to default+IMU). All looked good (response, vibration, etc).
Second (Autotune) Flight: I ran the Autotune (grit my teeth with aggressiveness set to 0.1). Autotune completed successfully for Pitch and Roll. I flew the default vs. autotune PIDs at the end of the flight and the autotune PIDs seemed similar but somewhat tighter overall as expected.
When I looked at the default vs autotune PIDs in Mission Planner, I noticed something strange:
Autotune PIDs (with default values in parentheses):
* Stabilize Roll (Error to Rate) = 8.840641 (default was 4.50)
* Rate Roll, P = 0.09606013 (default was 0.135)
* Rate Roll, I = 0.09606013 (default was 0.090)
* Rate Roll, D = 0.00527265 (default was 0.0036)
* Rate Roll, IMAX = 0.5
* Rate Roll, FILT = 10
* Stabilize Pitch (Error to Rate) = 11.78815 (default was 4.50)
* Rate Roll, P = 0.1167617 (default was 0.135)
* Rate Roll, I = 0.1167617 (default was 0.090)
* Rate Roll, D = 0.00824510 (default was 0.0036)
The P and I values are EXACTLY THE SAME! This is true for both Pitch and Roll. It’s as if the value of one of the parameters got stored for both the P and I values (?)
I thought I could maybe figure this out by looking at the log file, but I had set the LOG_BITMASK back to “default” (830 -> ATTITUDE_MED, GPS, PM, CTUN, NTUN, CMD, and CURRENT) before the autotune flight and no ATUN or ATDE parameters were captured. I assumed that the ATUN and ATDE would be logged since there was no reminder in the “Dataflash logging” section of the doc under autotune to set the LOG_BITMASK to anything besides default - I should have researched further.
So, my questions are:
  1. Is it typical to have the P and I values be the exact same after autotune (as above)?
  2. How should I set the LOG_BITMASK to capture the autotune (ATUN and ATDE) parameters? Is it the PID (12) bit that I need to set? Is there a better description of what is captured for each of the mask bits (i.e., what does setting bit 12, the “PID” bit log?)
Thanks!
I dont know enough to say whether or not that is expected behavior, but I can tell you that my auto tune resulted in the same - P & I were equal.
I had to return my Cube for the service bulletin, and im just now setting up my replacement. Havent flown autotune on the new cube yet.
P and I are always the same in auto tune… It’s always ‘good enough’. You’re certainly able to fine tune your copter and adjust those values from what you get in auto tune.
Thanks for the insight. I just found it odd – at first glance, it appears that one of the values is getting copied to the wrong parameter. I guess setting the two values to be equal a good starting place to start fine tuning (?) Since this is my first time tuning a big quad, I am looking for good ‘rules of thumb’ or some additional steps to check/improve the tuning. Such as the comment in the doc that says something like, “When D is too low, you will experience the worst prop wash oscillations in vertical descents” – something I can test and relate one to one.
Oh, also, what is the best way to turn on the ATUN and ATDE parameters in the log with LOG_BITMASK? I don’t want to bog down the processor unnecessarily, but want to capture the tuning details. What bits should be on? Is there a good reference for this?
