Where I have a issue is with the procedure I think. Let me explain now that i’m on my computer.
Yesterday, I spent a good hour or so attempting to autotune my tarot hexacopter multiple times. I had my laptop, telemetry radio, Jumper t-16 with Yaapu, and a printout of the autotune procedure from the Wiki. The Jumper t-16 has a 6 position push button switch for flight modes. Set up for me as follows, Stabilized, Pos 1, AltHold Pos 2, Loiter Pos 3, Autotune Pos 4, Pos 5 and 6 are RTL.
I took off in stabilized mode, gained altitude to about 60 feet, put the craft into altitude hold, made sure it was stable, then invoked autotune. Roll and Pitch autotune began. I was notified via Mission planner and yaapu telemetry that the autotune completed successfully. The craft was still in Autotune and happily hovering at this point.
I referred to the wiki pages I printed out before continuing,
" 6. When the tune completes the copter will change back to the original PID gains.
7. Put the ch7/ch8 switch into the LOW position then back to the HIGH position to test the tuned PID gains.
8. Put the ch7/ch8 switch into the LOW position to fly using the original PID gains.
9. If you are happy with the autotuned PID gains, leave the ch7/ch8 switch in the HIGH position, land and disarm to save the PIDs permanently."
I was a bit perplexed at step 7.
Since I don’t have high, or low, settings (I understand that high and low are electronics/software jargon), does this mean that I should switch flight modes? i.e. When autotune completes, switch to previous hold mode(Low), then back to autotune (High) to test the new PIDS?
Jumping to step 9, if the PIDs are satisfactory, remain in Autotune (High), Land in Autotune (High), disarm to save new PIDs permanently. Is this correct?
Not fully understanding the procedure, I attempted to land the craft, it was still in Autotune (High) state. I brought the craft in to land. I never changed from High to Low and back to High. I was able to bring the craft to the ground, but could not get it to disarm while the Autotune was still active from the Autotune session, yaapu telemetry mavlink messages kept saying pilot intervention whenever i tried to disarm. I couldn’t disarm from the radio, or from mission planner. I was scratching my head at this point . I decided, since nothing i was doing was working, I would I changed flight mode to Stabilized, and see if I could disarm the craft. That worked! I checked Mission planner, still the same default PIDs.
I would assume, since I did not alter the state of the autotune, i.e. High to Low back to High before landing, the Autotune software loop assumed it was still running which is why i could not disarm?
By the way, I am a retired USAF aircrew. We had checklists for everything.
