Our vessel works as expected in MANUAL mode. However, after we set it to GUIDED mode and send a waypoint by clicking on the map and selecting “go there,” it does some random and weird movement around the pool. It is not acting as expected.
On top of that, when we write the same parameters into SITL and test there, it also moves randomly.
you need to un reverse any rc channels on your handset and start again. any fixes like that need to be done in mission planner at the servo output page.
While a bi-directional ESC is probably preferable, I think your problem relates to reversing an input (RC channel) when you probably needed to reverse an output (servo channel), instead.
david can you help me in connection of two boats telemetry i am complete beginner i want my two boats to operate on single mission planner what should i do step by step i am two 3DR radio telemetry 433hz . now what should i do next thanks
david i have fs i6b which i connected to my pixhawk 2.4.8 rc in port my problem is not long range . 500m is fine for me i want my twopixhawk data on one missionplanner screen . what should i do with my telemtry of two boats to connect to my ground station( mylaptop) ground 3dr radio telemetry antenna
1st change the NetID on the Telemetry Radios to unique numbers. Connect both Ground Telemetry Radios to the laptop. In Mission Planner connect the 1st radio as usual. Then right click on the top bar and select Connection Options. Then pick the 2nd radio and baud rate and hit Connect.
This is showing a rover and a multirotor both connected.
