Hi - I have run through the setup and first run work flows for setting up and automission… I have my rover with mission set, outside, good satellites armed and ready for mission… but nothing happens… what actually initiates the rover to start?
I’m missing something simple I fear. what are the basic steps?
I have disabled the safety button…so not a factor I think.
Yes vehicle arms…i set a simple mission in the back yard.
Switches to auto… Then just a long beep …and nothing.
Yes drives manually fine etc…
Log posted below
Something i have noticed which maybe the problem… the motor controller is a sabretooth 60a… I had on mixed mode, using the right joy stick only to control skid steering.
However the motor test wasn’t working…
as per the ardurover setup instructions - I have changed the sabre to separate channels, and RC1 to Left Throttle, and RC2 to right throttle… but now nothing works.
