Hi, this is first time I am using turbine engine aircraft (jetcat p220) coupled with a flight controller for automatic take-off function, the problem I am currently facing is that when setting up my flight controller (Pixhawk Orange cube) for this mode I am unable to understand how to initialize optimum conditions, What I want is that when I switch my aircraft in auto take-off mode then following things should happen:
- my throttle should increase to 100%
- delay should occur for 5 sec, which means for 5 secs my throttle will be kept at 100%
- a 5v signal was sent from the flight controller to my catapult in the lock mechanism to release the lock for launch
- aircraft then starts to accelerate and increase the altitude to up to 800 meters at an angle of 20 degrees
- after reaching 800 meters it should cruise or switch to FBWA mode
My aircraft thrust-to-weight ratio is 1.2, my launcher is heavy enough to hold the aircraft at 100%, and the launch angle of my launcher is at 15 degrees, for smooth operation, I have used rail guides
Any kind of help is very much appreciated.
