I need to operate in an area with by wildfires, this environment is affected by strong winds and upwards movement of air that destabilized my VTOL. I have an onboard computer on my VTOL and would like to implement a stabilizer for this environment, where i am using a thermal camera to effectively avoid the more dangerous zones, but i need fine control over the drone.
I would like to know if arducopter supports a attitude control method in guided mode? The available documentation feels quite confusing. Is it the same as in quadcopter? Can i use a velocity control in fixed wing mode?
The solution is intended for real-time wildfire mapping, i can map them quite well, but can’t operate safely in the environment. I have models to understand what is best attitude given the current aerodynamics, but not sure if i can use them with ardupilot.
